It is currently Sun Jul 13, 2025 7:51 pm
 Post subject: New rubber uni joints
PostPosted: Wed Oct 10, 2018 12:38 pm
These appear really tight and the u bolt spread a little larger than hole alignment
Any experience with these ?
Should I bend the bolt and jam it in?
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Wed Oct 10, 2018 12:48 pm
Yes...the U Bolts spring "open"...gently squeeze them in a vice or gently tap with a BFH close to the threaded end or run 2-3 old nuts on each end before hitting or clamping (to save damaging the threads)...then they should slide right in...
PostPosted: Wed Oct 10, 2018 5:44 pm
Many thanks 9ya, it had me a little ba’fooled’
Simonw
Brisbane QLD
- 1969 Mini K
PostPosted: Thu Oct 11, 2018 10:01 pm
No problem simon...advice and help is what AUSMINI is all about :wink: :)
