It is currently Sun Jul 13, 2025 5:56 am
 Post subject: transmition “whir”
PostPosted: Mon Oct 08, 2018 6:04 pm
Gday folks,
I’ve got a 78 1275LS.
I’m having some minor concerns over how much noise is coming from the gearbox
It sort of sounds like a straight cut gearbox noise. Whirring etc.
Gears still change crisply and engage fine.
Just wondering what level of noise is deemed “normal” for minis and if I should be alarmed
PostPosted: Mon Oct 08, 2018 7:28 pm
Have you had the car long? In other words, has this noise just started, or always been there?
Is the noise in time with each gear?
Is it as you go through the intermediate gears but not in top gear?/ or in all gears?
Is it in time with the wheel rotation/car speed?
PostPosted: Mon Oct 08, 2018 7:45 pm
So it literally sounds like a strait cut gear box.
No noise when clutch is in.
It doesn’t seem to have anything to do with the wheel rotation/car speed. Just occurs when gears are engaged.
PostPosted: Mon Oct 08, 2018 7:47 pm
I’ll try and take a video and post tomorrow.
PostPosted: Mon Oct 08, 2018 8:08 pm
If the noise stops when the clutch is depressed, it could be a loose idler gear (thrusts have worn).
"64 Smooth Roof Van (Colin)
PostPosted: Tue Oct 09, 2018 10:41 am
My question about wheel rotation was to find out which part of the box is moving when the noise occurs.
With the clutch in, the whole gearbox is slowing down and no load is going through it; suggests the problem is in the gearbox.
Just a guess but could it be worn layshaft/or bearings moving layshaft gear teeth engagement with mainshaft gears apart to a slightly different position?
PostPosted: Tue Oct 09, 2018 1:23 pm
I’m having trouble uploading a video.
But when stand still and in neutral with clutch out, it does not really make any obvious angry noises.
It’s more obvious in first and second gears. Particularly on engine braking and down shifting from 3rd to second. You can hear 2nd gear spooling up to the rpm on the engine.
I may just have to take it in for diagnosing.
PostPosted: Tue Oct 09, 2018 2:19 pm
Location?
PostPosted: Tue Oct 09, 2018 2:40 pm
Can you upload the video to YouTube or Vimeo and then provide a link?
PostPosted: Tue Oct 09, 2018 4:59 pm
I’ll give that a go tonight.
PostPosted: Tue Oct 09, 2018 5:28 pm
https://youtu.be/Ux849WVGL3k
PostPosted: Tue Oct 09, 2018 7:07 pm
so far that sounds pretty normal but try that again but this time get into 4th to show if the noise goes away. The whine normally is because at some point the main gearbox bearing has collapsed but still used and worn the gear set on a slight angle, new bearing will not fix that. If the noise goes away in 4th it's more than likely layshaft bearings as the layshaft is not used in top gear.
PostPosted: Tue Oct 09, 2018 7:28 pm
sounds the same as my LS and its fine
PostPosted: Thu Oct 11, 2018 5:58 pm
My rebuilt-by-a-professional rod change box sounds like a straight-cut also. I was initially confused, but it performs flawlessly, so I'm not bothered by it anymore :)
PostPosted: Fri Oct 12, 2018 9:43 am
I have some whiirrrrrr as well, always been there and all the members in my family that drove mini's say it reminds them of when they drove.
https://www.youtube.com/watch?v=CX9SVcXD4Mk
Nick
