https://ausmini.com/forums/
Rear seat belt mounting points images reupload please
https://ausmini.com/forums/viewtopic.php?f=2&t=97806
Author:  lolomovil [ Mon Oct 01, 2018 9:16 pm ]
Post subject:  Rear seat belt mounting points images reupload please
Hello from Spain, i'm looking for info about the rear seat belt mounting points and i found two threads about it
http://www.ausmini.com/forums/viewtopic.php?f=2&t=84411&hilit=seat+belt+rear+shelf
http://www.ausmini.com/forums/viewtopic.php?p=626757
but i couldn't see the images as they're in a photobucket server.
If someone could upload images of the reinforcements of the rear shelf I will be very grateful as I want to reinforce mine to install rear belts.
Author:  hpal [ Mon Oct 01, 2018 10:28 pm ]
Post subject:  Re: Rear seat belt mounting points images reupload please
Here’s what I’ve done with mine. Reinforced with 3mm plate and made a 50mm high riser to sit the retractable seatbelt reels on. I will get it engineered when the car is on the road.
Author:  timmy201 [ Tue Oct 02, 2018 6:56 am ]
Do you know if you have local regulations in your country about seatbelt points?
Somerford mini in the UK do a weld in kit the same as the late UK cars
https://www.somerfordmini.co.uk/news-ev ... unting-kit
Author:  lolomovil [ Tue Oct 02, 2018 7:54 am ]
Hello and thanks for the answers. In my country the later minis have the factory fitted plates similar to Someford kit.
The problem is that the installation requires welding to c-posts and my car is already painted so I'm looking for a solution similar to that adopted by Australian minis that does require welding in non sensible areas or a non welding approach (like hpal in previous post).
I have also seen the approach adopted by forum member Morbo28 in this post http://www.ausmini.com/forums/viewtopic.php?f=3&t=86822&start=795. Morbo28 comments that is guided by an engineer.
Author:  Matt I [ Tue Oct 02, 2018 9:46 am ]
No spreader plate is going to be much good when the panel it's attached to can't take the load... Factory cars with seatbelts mounted to the parcel shelf had a lot more reinforcement between the main panel and the body.
Author:  1071 S [ Thu Oct 04, 2018 5:55 pm ]
My thoughts exactly.. The red reinforcing plate shown above does nothing to distribute loads away from the parcel shelf.... and is a complete waste of weight and money...
Have look at the reinforcing plates that Leyland installed....
Cheers, Ian
Author:  hpal [ Thu Oct 04, 2018 8:04 pm ]
I’ll let my engineer be the judge, if he’s happy then I’m happy.
