https://ausmini.com/forums/
pistons - Morris Cooper 997
https://ausmini.com/forums/viewtopic.php?f=2&t=97781
Page 1 of 2
Author:  John Sneddon [ Wed Sep 19, 2018 9:04 pm ]
Post subject:  pistons - Morris Cooper 997
Can anyone point me to where I may find a supply of 997cc pistons, both Mini Spares and Somerford no longer carry stock of the pistons only the rings.
Author:  simon k [ Wed Sep 19, 2018 10:22 pm ]
Post subject:  Re: Morris Cooper 997
moved to mini chat John... I think it's more of a "help please!" than a "wanted to buy"
Author:  Goldbrocade_62 [ Thu Sep 20, 2018 8:03 am ]
Post subject:  Re: pistons - Morris Cooper 997
Is JP pistons still around they used to do them and many other classics
Author:  goodie [ Thu Sep 20, 2018 8:19 am ]
Hi John , I do know a guy that has / had these , not sure if they are exactly what your after .
Author:  drmini in aust [ Thu Sep 20, 2018 8:32 am ]
Are 998 Cooper above.
I would bore it and fit 1098 ones. Then deck block a little to suit. Stroke isn't much less than 1098 is.
I bored a 997 block to 68mm years ago they are pretty thick walls.
Author:  timmy201 [ Thu Sep 20, 2018 8:34 am ]
These are apparently NOS std size ones
https://www.ebay.co.uk/itm/Mini-Cooper- ... 2101157780
You can also try on this UK forum which focusses on early cars
http://mk1-forum.net
Author:  9YaTaH [ Thu Sep 20, 2018 8:37 am ]
https://www.norndaautomotive.com.au/
Author:  winabbey [ Thu Sep 20, 2018 8:47 am ]
https://www.norndaautomotive.com.au/jp- ... CR%209.4:1
Author:  John Sneddon [ Thu Sep 20, 2018 12:44 pm ]
Thank you for your responses - looks like I may be on the right path now.
Just measured the engine and to my delight the bore and crank are both still standard, may require clean up maching though.
Author:  drmini in aust [ Thu Sep 20, 2018 3:22 pm ]
Crack test the 997 crank they are well known to crack. :wink:
At front or rear web.
Author:  wild_willy [ Fri Sep 21, 2018 8:53 am ]
Hi John
I have sent you a PM
Author:  AWOODY [ Fri Sep 21, 2018 4:30 pm ]
A little off topic but are original airfilter pancake type for coopers rare sought after etc ??
Author:  Goldbrocade_62 [ Fri Sep 21, 2018 4:50 pm ]
I think thery are remade in the uk
Author:  Matt I [ Fri Sep 21, 2018 5:54 pm ]
I thought the repro ones were not correct in the way they mounted... Might have a pair of originals here somewhere :P
Pairs of originals I have seen on UK ebay have generally sold for quite a bit...
Author:  Goldbrocade_62 [ Fri Sep 21, 2018 6:40 pm ]
Mk1 sprite and cooper are almost the same one has captive nuts and one has bolts that go thru maybe the uk repro is sprite
