Mk1 Aussie mini 1964. https://ausmini.com/forums/viewtopic.php?f=2&t=97778 |
Author: | hellomick [ Wed Sep 19, 2018 5:28 pm ] |
Post subject: | Mk1 Aussie mini 1964. |
Hi, need help with door rod inside door one end has long slot other end short slot what end fits on door opener on outside handle. Cheers Michael.... |
Author: | timmy201 [ Wed Sep 19, 2018 11:09 pm ] |
Post subject: | Re: Mk1 Aussie mini 1964. |
Doesn’t look like anything on my 1964 doors? Do you have wind up windows or the original sliding ones? |
Author: | drmini in aust [ Thu Sep 20, 2018 3:29 pm ] |
Tim, That rod is used on windup window doors not sliding 850 ones. |
Author: | hellomick [ Fri Sep 21, 2018 12:19 pm ] |
Sorry for late response.....yes wind up window....any help out there what end to outside door handle cheers Michael. |
Author: | Bill B [ Fri Sep 21, 2018 1:43 pm ] |
These are handed L&R. The Miniking catalogue seems to show the longer slot to the rear. My notes from when I did my doors, I have the LH link rod with offset at both ends towards the outside of the door - the centre section therefore closer to the inside of the car. Also the bar bends downwards at the front edge of the door. |
Author: | Hinesy1275 [ Fri Sep 21, 2018 2:49 pm ] |
As Bill B has suggested above, and with the longer slot to the outside handle mechanism |
Author: | hellomick [ Thu Feb 07, 2019 6:31 pm ] |
Thanks you for replys i appreciate the effort you went too.thanks again.michael |
