https://ausmini.com/forums/
BPR5ES or BPR6ES
https://ausmini.com/forums/viewtopic.php?f=2&t=97769
Page 1 of 3
Author:  jme [ Sun Sep 16, 2018 3:44 pm ]
Post subject:  BPR5ES or BPR6ES
I'm changing the spark plugs, engine is 1275 with twin 1.25 SUs and very mild cam, what is the consensus on the best spark plugs?
Author:  Stibbsy [ Sun Sep 16, 2018 4:23 pm ]
Post subject:  Re: BPR5ES or BPR6ES
Champion N9Y or N9YC cooper core and you can still buy them.
Author:  DavidE [ Sun Sep 16, 2018 5:07 pm ]
One two many "o"s and one too few "p"s?
Author:  AEG163job [ Sun Sep 16, 2018 8:03 pm ]
Are these any good?
https://www.ebay.com/itm/CHAMPION-SPARK ... 2749.l2649
Author:  drmini in aust [ Sun Sep 16, 2018 9:29 pm ]
NGK BPR5ES these days.
Rumour has it resistor plugs give a hotter spark,
BP recommend 1 heat range hotter for unleaded fuel,
NGK plugs are made in Japan, not Mexico or elsewhere.
Author:  850 GT [ Sun Sep 16, 2018 10:01 pm ]
NGK all the way, have used them in race cars for years. no probs.
Author:  Matt I [ Sun Sep 16, 2018 11:35 pm ]
NGK BP5ES over here, 10:1cr 1275 with a cam.
Author:  simon k [ Mon Sep 17, 2018 9:23 am ]
yeah, 5's are what you want
Author:  jme [ Mon Sep 17, 2018 12:43 pm ]
I previously had problems with plug fouling in the queue for the motorkhana where it idles for ages (maybe 15-30 minutes) and only has a 30 second or less run before waiting another 15-30 minutes in the queue. Is it worth going one heat range hotter (i.e. BP6ES)?
Author:  gtogreen1969 [ Mon Sep 17, 2018 12:51 pm ]
5 is hotter than 6
Author:  AEG163job [ Mon Sep 17, 2018 1:06 pm ]
Not sure letting an A series idle for prolonged periods is such a good idea.
Less/insufficient splash lubrication for the bores/pistons at low engine speeds.
But waiting in a 'khan queue maybe no options, unless you push it along!
Author:  GuamMini [ Thu Feb 28, 2019 3:27 pm ]
I was using a BP6ES and it fouls after idling for a while so now I am going to try a BPR4ES. My question is on my 1973 Clubman GT do I use 91 or 87 unleaded fuel or do I use a lead additive and which octane fuel rating? thanks
Author:  gtogreen1969 [ Thu Feb 28, 2019 3:35 pm ]
Use 95 or 98 fuel. Why are you jumping BP5 and going straight to BP4?
Author:  timmy201 [ Thu Feb 28, 2019 4:23 pm ]
I think Guam would use the same octane rating as the US:
98 RON (AUS) is about the same as 93 AKI (US)
95 RON (AUS) is about the same as 91 AKI (US)
Author:  GuamMini [ Thu Feb 28, 2019 4:51 pm ]
I am tired of buying plugs so I thought 4 should be better. The 6 lasted for a few months. Yes we have 87 and 91 AKI. No 93. Do I need to add a lead substitute? I have not been using one.
Page 1 of 3 All times are UTC + 10 hours
