https://ausmini.com/forums/
Found in Oil. What is it?
https://ausmini.com/forums/viewtopic.php?f=2&t=97693
Author:  phillb [ Sun Aug 26, 2018 4:40 pm ]
Post subject:  Found in Oil. What is it?
This was stuck to the end of my magnetic oil plug. Any ideas what it might be. It is a odd shape. Cylindrical but with rounded ends and flat sides. It has perfectly formed flat spots either end.
There is a possibility it just got picked up by the plug during the oil change (eg off the garage floor) because I didn’t notice it till I went to replace the sump plug.
It doesn’t look to be chewed up or marked.
.Image
Author:  Morbo28 [ Sun Aug 26, 2018 7:29 pm ]
Post subject:  Re: Found in Oil. What is it?
Looks like it might be a roller from a bearing? Then again, I've got bearings on the brain at the moment.
Author:  peterb [ Sun Aug 26, 2018 7:32 pm ]
Looks like it's been rattling around in there for a while if its a bearing roller. Would have been a disaster if it had got caught between gears.
Author:  drmini in aust [ Sun Aug 26, 2018 8:37 pm ]
Sits on reverse selector arm, in bottom of remote box? Engages reverse selector rod. I think... Maybe.
Author:  850man [ Sun Aug 26, 2018 8:44 pm ]
It looks like a roller out of the Input gear support bearing, that has been bouncing around in the gearbox for a while.
Author:  Scoop [ Sun Aug 26, 2018 8:48 pm ]
I would guess at it being some sort of selector detent like what the Doc said.
Author:  drmini in aust [ Sun Aug 26, 2018 9:49 pm ]
Hard to see from pics, if no hole in it I agree it's probably an outrigger bearing roller. Somewhat beat up. :wink:
Author:  simon k [ Mon Aug 27, 2018 10:14 am ]
that's kinda what I was thinking, it's the right size, but it's a little bit too perfectly shaped - they're a nice square cylinder shape (the only type I've seen have been a cylinder, there may be other shapes out there)
if it was picked up off the garage floor, what would it have been doing there? where might it have come from?
Author:  phillb [ Mon Aug 27, 2018 10:20 am ]
Yeah I’m thinking more likely not from elsewhere (just me being hopeful) because I think the sumpplug just stayed in the drain tub. I thought it might have popped out of a socket spanner.
I actually had a gearbox circlip come out with the oil years back, it’s in a thread on here somewhere.....
