Under engine steady bracket rubbers https://ausmini.com/forums/viewtopic.php?f=2&t=97688 |
Author: | AWOODY [ Fri Aug 24, 2018 8:37 pm ] |
Post subject: | Under engine steady bracket rubbers |
As above I have and old fashioned engine steady bracket that goes from the bottom of the engine to the subframe .... you know the type but the rubbers have worn out any clues on new ones where to get them are they used for something else etc |
Author: | Matt I [ Fri Aug 24, 2018 10:24 pm ] |
Post subject: | Re: Under engine steady bracket rubbers |
The currently available style use the same bushes as the uppers. |
Author: | drmini in aust [ Sat Aug 25, 2018 7:41 am ] |
The original lower steady from the 60s (threaded rod) used similar rubbers to the top of rear shocks. Maybe bigger bore, check out using these from a bigger car. Matic's lower steady was similar I think. |
Author: | AWOODY [ Sat Aug 25, 2018 8:30 am ] |
Mmm, thanks good start . |
Author: | AWOODY [ Wed Aug 29, 2018 8:29 pm ] |
Well I tried the top of the shock rubbers but they are too big and too soft , need more suggestions , the rod is the same as a 5/16 drill . |
