It is currently Sun Jul 13, 2025 7:50 pm
 Post subject: HS2 SU Carbs ID.
PostPosted: Thu Aug 30, 2018 3:33 pm
OK, time to build up my HS2 carbies. Is there any difference between HS2 AUD146 and HS2 AUD440 when it comes to build and fitment to a 1275? (apart from production dates)
Also, can anyone offer advice on kit quality for the various build kits in the marketplace?
Thanks in advance.
1970 Mk2
1968 Mk1 project
 Post subject: Re: HS2 SU Carbs ID.
PostPosted: Thu Aug 30, 2018 3:55 pm
The later ones had the port for the CCV breather (or at least the casting with a blank on it).
I ordered a CRK101 kit from SU Midel in Sydney and they turned out great (thanks to Mick)
PostPosted: Thu Aug 30, 2018 3:57 pm
The rebuild kits should cover all the different HS2 carbies.
The 146 and 440 are listed as having the same M needles and red piston springs.
