It is currently Mon Jul 14, 2025 4:55 am
 Post subject: Dash light
PostPosted: Mon Aug 13, 2018 8:56 pm
My dash/speedo light is so dull to the point where I can't see what speed I'm travelling at night- not good! Checked the globes and all is good. Is this normal? Any suggestions?
 Post subject: Re: Dash light
PostPosted: Mon Aug 13, 2018 10:12 pm
What model? Could be something as simple as a loose connection.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Mon Aug 13, 2018 10:15 pm
If its a Clubman / Leyland then it should have an adjustable Rheostat Dimmer Switch. Usually under the dash next to your right knee. It has a black knob with a P on it. Bypassing it will give you full 12v and bright panel lights.
PostPosted: Thu Aug 16, 2018 9:54 am
Don't go putting higher wattage Bulbs in the Cluster. It has disastrous consequences. I also have new Dash Light dimmers $35.00 if any one is interested PM me.
"Let us remove your "SHORTS"
PostPosted: Fri Aug 17, 2018 5:51 am
Just wondering what is the correct wattage for an old smiths tachometer. I have a similar problem that it is quite dim compared to the standard dash.
PostPosted: Fri Aug 17, 2018 8:18 am
Bulbs in Cluster should not exceed 3 watts.
PostPosted: Fri Aug 17, 2018 3:41 pm
I am with you Phil so is the bulb for the tachometer still 3 watts ? Is there some way to improve it ?
PostPosted: Fri Aug 17, 2018 5:18 pm
LED bulb perhaps?
PostPosted: Sat Aug 18, 2018 5:06 pm
The standard bulb that came with the Smiths tacho and other Smiths gauges is Lucas LLB987 at 2.2 watts.
https://www.ebay.com.au/itm/10-x-LUCAS- ... 1302884767
Users browsing this forum: No registered users and 67 guests
