https://ausmini.com/forums/
Dash light
https://ausmini.com/forums/viewtopic.php?f=2&t=97640
Author:  Chevrons [ Mon Aug 13, 2018 8:56 pm ]
Post subject:  Dash light
My dash/speedo light is so dull to the point where I can't see what speed I'm travelling at night- not good! Checked the globes and all is good. Is this normal? Any suggestions?
Author:  Scoop [ Mon Aug 13, 2018 10:12 pm ]
Post subject:  Re: Dash light
What model? Could be something as simple as a loose connection.
Author:  gtogreen1969 [ Mon Aug 13, 2018 10:15 pm ]
If its a Clubman / Leyland then it should have an adjustable Rheostat Dimmer Switch. Usually under the dash next to your right knee. It has a black knob with a P on it. Bypassing it will give you full 12v and bright panel lights.
Author:  Convertible Mini [ Thu Aug 16, 2018 9:54 am ]
Don't go putting higher wattage Bulbs in the Cluster. It has disastrous consequences. I also have new Dash Light dimmers $35.00 if any one is interested PM me.
Author:  phillb [ Fri Aug 17, 2018 5:51 am ]
Just wondering what is the correct wattage for an old smiths tachometer. I have a similar problem that it is quite dim compared to the standard dash.
Author:  Convertible Mini [ Fri Aug 17, 2018 8:18 am ]
Bulbs in Cluster should not exceed 3 watts.
Author:  AWOODY [ Fri Aug 17, 2018 3:41 pm ]
I am with you Phil so is the bulb for the tachometer still 3 watts ? Is there some way to improve it ?
Author:  timmy201 [ Fri Aug 17, 2018 5:18 pm ]
LED bulb perhaps?
Author:  winabbey [ Sat Aug 18, 2018 5:06 pm ]
The standard bulb that came with the Smiths tacho and other Smiths gauges is Lucas LLB987 at 2.2 watts.
https://www.ebay.com.au/itm/10-x-LUCAS- ... 1302884767
