It is currently Mon Jul 14, 2025 4:57 am
 Post subject: Penrite mini oil
PostPosted: Wed Aug 15, 2018 8:42 pm
Any good Looks to have additives good for cam and lifters .Is it a good break in oil.??? :?:
 Post subject: Re: Penrite mini oil
PostPosted: Thu Aug 16, 2018 7:31 pm
I hate to make comments about oil as I don't know anything about oils or their qualities and suitability.
I have used Penrite Classic Mini oil and it improved the gearchange (as synchros are getting worn).
Recently had an S motor built by an old specialist in A and B series motors and his recommendation was Penrite HPR30 for running-in and regular use.
Have used HPR30 in other minis in recent years and seems OK -especially with worn synchros and seems about the same as the Mini Classic oil and both are intended for similar type engines.
PostPosted: Thu Aug 16, 2018 8:28 pm
Thanks Bill .The lead is gone same as in my solder for work .Gone in paint too and I dont think modern technology has a worthy replacement Zinc maybe for motors.
PostPosted: Fri Aug 17, 2018 8:53 am
Hi Ian_B
I use Penrite HPR 30 as well and have done so since 2003 for my Cooper S.
It was recommended as in Bill's case by a well known engine rebuilder.
I'm more than happy with the product.
Regards Pete.
PostPosted: Fri Aug 17, 2018 10:17 am
Firefirey wrote:
Hi Ian_B
Regards Pete.
you should be using 5-30W castrol Edge for the R53 engine
PostPosted: Fri Aug 17, 2018 7:41 pm
brett wrote:
Firefirey wrote:
Hi Ian_B
Regards Pete.
Sorry to disappoint you :-) but the HPR 30 oil is for my 1970 Mk 2 Cooper S.
I finished restoring it in 2003 :-)
But I do use Castrol Edge 5w-30 in my VW Golf GTI.
PostPosted: Fri Aug 17, 2018 8:06 pm
Lol I read it as 2003 Cooper S (R53) ☺
