It is currently Sun Jul 13, 2025 9:17 pm
 Post subject: Coxhead Flywheel puller
PostPosted: Sun Aug 12, 2018 5:54 pm
I’m just wondering what a Coxhead flywheel puller, and Primary gear seal installer set would be worth these days. (Sorry I'm not selling it, I just picked it up today)Image
1970 MK II Cooper 'S' Supercharged 1310 with Megajolt.
1970 MK II Cooper 'S' Original resto project (SOLD)
1962 850 Original. (Under restoration)
1973 Leyland S (My first car. Now rebuilt, so my kids can learn how to drive a real car).
VMCI # 215.
PostPosted: Sun Aug 12, 2018 6:35 pm
$10 if you don't need one and $300 if you do. :lol:
PostPosted: Sun Aug 12, 2018 7:45 pm
man, that flywheel puller would be sweet. Nev Purdue in Ballarat once told me that he had one that type and loaned it to another workshop to pull a flywheel. Next time he went to use it the grease came oozing out of a crack, they'd hit it with a hammer and f*cked it
PostPosted: Sun Aug 12, 2018 8:30 pm
I’d say PeterB is pretty close to the money.
PostPosted: Mon Aug 13, 2018 7:39 pm
I have seen a Coxhead puller sell for $700. Yes, they are that good.
PostPosted: Mon Aug 13, 2018 9:34 pm
WOW! Thanks guys, I was thinking around the $200-$300 mark.
Already have the first job lined up for it next weekend.
VMCI # 215.
PostPosted: Tue Aug 14, 2018 4:05 pm
The two sets of studs are for the two types of clutch, the early coil spring type and the usual diaphragm type.
On the early coil spring ones the studs are also used as a spring compressor with the domed nuts facing the other way.
PostPosted: Wed Aug 15, 2018 3:26 pm
& i wouldn`t use the center-plug to push on,,, we use the flywheel bolt (without the key-washer fitted)
because the flywheels can come flying off, hit you in the guts, then land on your toes,,, i`ve seen a flywheel shoot across the workshop years ago :-)
PostPosted: Wed Aug 15, 2018 5:19 pm
early 850 flywheel bolt ;)
