https://ausmini.com/forums/
Clubman style door handle exterior - Help
https://ausmini.com/forums/viewtopic.php?f=2&t=97634
Author:  Hobson [ Sun Aug 12, 2018 4:59 pm ]
Post subject:  Clubman style door handle exterior - Help
Having an issue with the driver side, cannot actuate the door lock with the exterior handle.
The bell crank is actuating but I cannot see what isn't, has anyone had this issue before? prior to me tearing it all apart to have a look? or any ideas on what i should be looking for?
Author:  peterb [ Sun Aug 12, 2018 6:26 pm ]
Post subject:  Re: Clubman style door handle exterior - Help
There might be too much free play, the link is adjustable by moving plate up/down.
Author:  Hobson [ Fri Aug 24, 2018 10:59 am ]
Does anyone have a loose latch mechanism they can take photos of?
Author:  bluehishouse [ Mon Aug 27, 2018 6:34 am ]
Are you trying to shut the door with tge handle up to lock it? Cos that doesn't work. Found that out the hard way. Only locks by key i believe
Sent from my SM-G950F using Tapatalk
Author:  Hobson [ Tue Sep 04, 2018 11:11 am ]
No, The lock works fine, the internal handle works for both locking and opening when I lift the external handle (which connects to the part with the spring on it) it doesn't actuate the latch mechanism. I Believe that there is a failure behind the plate in the latch unit, so it isn't allowing the catch to release.
I have a lead on a spare I just need to go and get it.
Author:  Hobson [ Mon Sep 10, 2018 2:23 pm ]
Bit the bullet and drilled the stud out that holds it together. The pin on the plate is broken.
Author:  Convertible Mini [ Tue Sep 11, 2018 9:16 am ]
Are these locks available new?
