It is currently Sun Jul 13, 2025 4:49 pm
PostPosted: Sun Aug 12, 2018 4:59 pm
Having an issue with the driver side, cannot actuate the door lock with the exterior handle.
The bell crank is actuating but I cannot see what isn't, has anyone had this issue before? prior to me tearing it all apart to have a look? or any ideas on what i should be looking for?
Nick
PostPosted: Sun Aug 12, 2018 6:26 pm
There might be too much free play, the link is adjustable by moving plate up/down.
PostPosted: Fri Aug 24, 2018 10:59 am
Does anyone have a loose latch mechanism they can take photos of?
Nick
PostPosted: Mon Aug 27, 2018 6:34 am
Are you trying to shut the door with tge handle up to lock it? Cos that doesn't work. Found that out the hard way. Only locks by key i believe
Sent from my SM-G950F using Tapatalk
http://www.ausmini.com/forums/viewtopic.php?f=3&t=93352
If I'm carrying on like a pork-chop, I'm having a great time.
If I go very quiet there's a very good chance I broke something.
PostPosted: Tue Sep 04, 2018 11:11 am
No, The lock works fine, the internal handle works for both locking and opening when I lift the external handle (which connects to the part with the spring on it) it doesn't actuate the latch mechanism. I Believe that there is a failure behind the plate in the latch unit, so it isn't allowing the catch to release.
I have a lead on a spare I just need to go and get it.
Nick
PostPosted: Mon Sep 10, 2018 2:23 pm
Bit the bullet and drilled the stud out that holds it together. The pin on the plate is broken.
Nick
PostPosted: Tue Sep 11, 2018 9:16 am
Are these locks available new?
"Let us remove your "SHORTS"
