door handle pull down type spring location 1970 https://ausmini.com/forums/viewtopic.php?f=2&t=97627 |
Author: | p7676 [ Sat Aug 11, 2018 5:02 pm ] |
Post subject: | door handle pull down type spring location 1970 |
Hello all ,does the door handle spring connect to the bottom screw on the handle ?after it slides over the shaft. TY Allen |
Author: | simon k [ Sat Aug 11, 2018 6:18 pm ] |
Post subject: | Re: door handle pull down type spring location 1970 |
the Australian supplement of the big red workshop manual has this to say.... Quote: Reverse the above (disassembly) procedure making sure that the door handle return spring arm is in the downward vertical position. Preload the spring by moving the spring arm through 90° to locate on the spacer under the forward securing screw not as good as a picture 'eh ![]() |
Author: | p7676 [ Sat Aug 11, 2018 10:02 pm ] |
thanks simon maybe someone has a pic |
