It is currently Sun Jul 13, 2025 9:15 pm
 Post subject: OEM Radio Clubman GT
PostPosted: Fri Aug 10, 2018 8:39 am
Did the 73' Clubman GT come with the factory radio? If it does how does the trim mount? Thanks
1973 Clubman GT - YG2S8 1637
 Post subject: Re: OEM Radio Clubman GT
PostPosted: Fri Aug 10, 2018 12:24 pm
it was a dealer fit accessory, it was housed in a box, that screwed to the dash board.. have a look in the brochures there is a leyland brochure showing it
PostPosted: Fri Aug 10, 2018 1:47 pm
I have looked through my GT pics and the majority do not have radios. They were an option and dealer fitted. The radio was an AWA MG17. A radio supplied and fitted in 1973 cost $110.
The Clubman and Clubman GT used the same mounting case with the radio located at the top and speaker at the bottom. Most of these have "Clubman" on the bottom left and "Solid State" on the bottom right.
Edit- Updated with more informationImageImage
PostPosted: Fri Aug 10, 2018 1:51 pm
I have that face plate just looking now for the pieces to mount it on the dash and how it is mounted, also the radio itself if I can find one
PostPosted: Fri Aug 10, 2018 4:39 pm
Does this help?
PostPosted: Fri Aug 10, 2018 5:20 pm
Here are a few Leyland radios used in the early to mid 70s.
The early Clubman radios were supplied by AWA so if you cant find a Leyland branded one then an AWA branded one would be the next best.
BMC ASTOR - Diamond dot was used by earlier minis.
Radiomoblie was used by later minis.
PostPosted: Sun Aug 12, 2018 10:34 pm
The buttonless version is the correct one for a clubman GT. Not all GTs came with a radio depending if the car buyer wanted to pay a few extra $ for one.
I have one that didn't have one and thus has no hole in the guard.
The same radio was also fitted to the mini clubman.
They seem to be a bit difficult to come by these days and have been sold in the past for several hundred $ (atleast asked for several hundred)
Sent from my SM-G935F using Tapatalk
PostPosted: Sun Aug 12, 2018 10:38 pm
This was the one fitted to the 1971 Magazine test cars.
PostPosted: Sun Aug 12, 2018 10:42 pm
That's the one.
Tried to quote your picture but couldn't get it to work on my phone.
Thankyou
PostPosted: Mon Aug 13, 2018 9:00 am
Nice great information, the radio would be a nice option to have in the car. I now need that base that holds the face and the radio, Thanks
PostPosted: Mon Aug 13, 2018 12:18 pm
http://www.gumtree.com.au/s-ad/woodland ... pp_android
PostPosted: Mon Aug 13, 2018 3:15 pm
Unfortunately that appears to have been chopped out and butchered
PostPosted: Mon Aug 13, 2018 3:22 pm
Yep. But he already has a facia.
Not much around at the monent. I have found over a dozen on FB but they are all sold.
PostPosted: Mon Aug 13, 2018 4:54 pm
I found the parts that I have for the radio. I need the radio only. I wish the face plate said Clubman
