Power output https://ausmini.com/forums/viewtopic.php?f=2&t=97602 |
Author: | ricksmini [ Tue Aug 07, 2018 7:51 am ] |
Post subject: | Power output |
Hi all just had an engine done and was wondering what sort of power I would get from it at the wheels. It's a 1275 20thou over light head work and 1:5 roller rockers 45 weber? |
Author: | drmini in aust [ Tue Aug 07, 2018 10:37 am ] |
Post subject: | Re: Power output |
Depends on what dyno, all are different. Mine made 76HP ATW on a Dyno Dynamics with an RE13 cam, and 86.6 with the RE282. See other specs below. But my head has big valves and ports, and the Redline manifold I spent 9 hours porting. |
Author: | deluxe67 [ Thu Aug 09, 2018 3:51 pm ] |
Like the good Doc says, it's very hard/ impossible to compare numbers from different dyno's in any meaningful way. For what it's worth (not much!), my engine which is more modified than yours, has a number of 75 Hp at the wheels at a place I would not recommend or go to again! |
Author: | gtogreen1969 [ Thu Aug 09, 2018 4:01 pm ] |
ricksmini wrote: Hi all just had an engine done and was wondering what sort of power I would get from it at the wheels. It's a 1275 20thou over light head work and 1:5 roller rockers 45 weber? At a guess - 50 to 55 An 80 BHP engine has about 50 Hp ATW. |
Author: | deluxe67 [ Fri Aug 10, 2018 2:12 pm ] |
What was a standard Cooper S at the wheels? |
Author: | gtogreen1969 [ Fri Aug 10, 2018 2:13 pm ] |
deluxe67 wrote: What was a standard Cooper S at the wheels? From Memory 45 HP ATW, 78 HP at the flywheel. I will do a search on here to see if there is any past discussions. |
Author: | gtogreen1969 [ Fri Aug 10, 2018 2:34 pm ] |
There is a bit about drive train loss here- viewtopic.php?f=2&t=66127&p=766424 |
