Interior indicators https://ausmini.com/forums/viewtopic.php?f=2&t=97596 |
Author: | Tomtax [ Sat Aug 04, 2018 10:57 pm ] |
Post subject: | Interior indicators |
Hi there all My binnacle green indicator lights both go on when the left or right indicators are put on. They are also not as bright as well. Maybe a short? Has anyone had a similar problem? Appreciate any thoughts Thanks |
Author: | gtogreen1969 [ Sat Aug 04, 2018 11:05 pm ] |
Post subject: | Re: Interior indicators |
Could be the flasher can playing up. Whats going on with the indicators outside? Are all 4 coming on at the same time? |
Author: | Tomtax [ Sat Aug 04, 2018 11:16 pm ] |
No the outside indicators are fine |
Author: | gtogreen1969 [ Sun Aug 05, 2018 12:23 am ] |
Try cleaning up all the connectors and plugs for the indicator switch and flasher can and see if that helps. |
Author: | rhaj [ Tue Aug 07, 2018 8:08 pm ] |
i've had the same problem on my Mini K, i was trying to use an electronic flasher can & it was doing the same thing as what you have said, i'm now using the std can type flasher unit & i've got no problems now, hope this helps you out |
Author: | Convertible Mini [ Tue Aug 07, 2018 8:30 pm ] |
If this is on a 2 pin flasher unit type system, You have the earth between the two warning lights missing and they are lighting up in series Getting half the voltage each. |
Author: | Tomtax [ Tue Aug 07, 2018 10:40 pm ] |
Thanks all. I will try your suggestions on the weekend Thanks again |
Author: | Tomtax [ Sun Aug 12, 2018 5:36 pm ] |
Replaced the flasher cam problem solved! Thanks all |
Author: | peterb [ Sun Aug 12, 2018 6:37 pm ] |
Some flasher cans have different connector lay outs, this can cause grief to the unsuspecting. |
