https://ausmini.com/forums/
Mini Tie Rod End question
https://ausmini.com/forums/viewtopic.php?f=2&t=97579
Author:  zulu_warrior1976 [ Fri Aug 03, 2018 11:04 am ]
Post subject:  Mini Tie Rod End question
Hi dudes,
See in the attached pictures the replaces tie rod end rubber. It has a torsion spring around the bottom. There is nothing sealing it at the top though. Does there need to be wire around the top of the rubber to keep it sealed?
Bman
Author:  simon k [ Fri Aug 03, 2018 2:41 pm ]
Post subject:  Re: Mini Tie Rod End question
nup, the rubber is pushed down the taper and the neck seals itself when you install them.
Author:  Scoop [ Fri Aug 03, 2018 9:27 pm ]
^^ What he said :)
Author:  zulu_warrior1976 [ Fri Aug 03, 2018 11:58 pm ]
Gentlemen,
Many thanks.
Regards,
Z
