Under chassis paint https://ausmini.com/forums/viewtopic.php?f=2&t=97578 |
Author: | Wildfoot [ Thu Aug 02, 2018 10:30 pm ] |
Post subject: | Under chassis paint |
Folks, currently restoring a mini van. What would be the best under chassis paint available. Something that I can paint over with 2 pac or acrylic. I hate rust so I prefer something rubberised or chunky. Thanks for the advice. |
Author: | peterb [ Fri Aug 03, 2018 6:33 am ] |
Post subject: | Re: Under chassis paint |
Do you mean the body deadner? |
Author: | Scoop [ Fri Aug 03, 2018 7:32 am ] |
peterb wrote: Do you mean the body deadner? Sounds like it. There are plenty of options out there. Have you spoken to your local auto paint supplier? |
Author: | Timinik [ Fri Aug 03, 2018 1:28 pm ] |
I used Gravi Tex plus. http://www.u-pol.com/uk/en-uk/product/upol/coatings-uk/specialist-coatings/gravitex-plus-hs-stone-chip-protector |
Author: | Wildfoot [ Fri Aug 03, 2018 2:52 pm ] |
Timinik wrote: I used Gravi Tex plus. http://www.u-pol.com/uk/en-uk/product/upol/coatings-uk/specialist-coatings/gravitex-plus-hs-stone-chip-protector Saw this at my local paint shop..looks like thsi is the way to go.... |
Author: | Wildfoot [ Fri Aug 03, 2018 2:53 pm ] |
Scoop wrote: peterb wrote: Do you mean the body deadner? Sounds like it. There are plenty of options out there. Have you spoken to your local auto paint supplier? Thanks Scoop. Had a look today... |
Author: | p7676 [ Fri Aug 03, 2018 5:28 pm ] |
The only one to use is stone guard which is used on modern cars It will have the same finish as the original coating. Most of the proofcotes will soften and bleed through the paint. Most professional restorers use stone guard because it has the best adhesion plus other advantages.2 pac is the way to go if you can afford it, also use a 2 pac epoxy primer on the whole car.The stone guard goes over the primer. Easy to apply. Allen |
Author: | Wildfoot [ Fri Aug 03, 2018 7:58 pm ] |
p7676 wrote: The only one to use is stone guard which is used on modern cars It will have the same finish as the original coating. Most of the proofcotes will soften and bleed through the paint. Most professional restorers use stone guard because it has the best adhesion plus other advantages.2 pac is the way to go if you can afford it, also use a 2 pac epoxy primer on the whole car.The stone guard goes over the primer. Easy to apply. Allen Allen, thanks. I will look for it. |
