https://ausmini.com/forums/
Copper Diff Thrust Washers
https://ausmini.com/forums/viewtopic.php?f=2&t=97557
Page 1 of 2
Author:  cooperess [ Sun Jul 29, 2018 6:49 pm ]
Post subject:  Copper Diff Thrust Washers
Where do you get the original copper thrust washer BTA101?
Author:  simon k [ Sun Jul 29, 2018 7:28 pm ]
Post subject:  Re: Copper Diff Thrust Washers
don't know that you can get them in copper - but then all of the old diffs I've pulled apart have had fibre washers in them anyway
Author:  Bill B [ Sun Jul 29, 2018 8:30 pm ]
There were copper ones early on. They were in the diff of my 1966 S, but mostly they are fibre now. Look at:
http://www.guess-works.com/Shop/Parts/d ... htm?id=174
and any local parts supplier, too.
Author:  Scoop [ Sun Jul 29, 2018 9:39 pm ]
I have always scrounged them out of old diffs. They will dry up one day though
Author:  cooperess [ Sun Jul 29, 2018 9:51 pm ]
When you say dry up, you mean they will no longer be obtainable --- don't you. As they are already not available new.
Author:  drmini in aust [ Sun Jul 29, 2018 10:11 pm ]
Were only in 3 synchro boxes. I have put them in my MK 2 S box.
They are bronze not copper.
Author:  Scoop [ Mon Jul 30, 2018 7:45 am ]
Correct.
Author:  cooperess [ Tue Jul 31, 2018 4:29 pm ]
Are you sure they're bronze and not copper?
Author:  slacko [ Tue Jul 31, 2018 5:20 pm ]
BTA101C
Minikingdom on line
Author:  drmini in aust [ Tue Jul 31, 2018 6:42 pm ]
Colour is too light for copper and they are hard.
I'm a machinist, I know the difference.
Note I am talking about the flat washers behind the side gears which are fibre on 4 synchro boxes.
Author:  cooperess [ Mon May 04, 2020 9:55 pm ]
Just wondering could these washers be sintered bronze?
Author:  drmini in aust [ Mon May 04, 2020 10:23 pm ]
Sintered bronze is brittle and porous. Mine are not. Look like sheet bronze.
Maybe are brass, but bronze is a better bearing surface.
Even brass would be better than fibre.
I don't like the currently sold fibre ones, they are too thick. Like the damned side cover gaskets are... grrr.
Why can't people make parts correctly. :x
Author:  cooperess [ Mon May 04, 2020 10:37 pm ]
Now I am confused "Brass" "Bronze" Sintered Bronze". Surely some here knows what material these are made of?
Author:  winabbey [ Mon May 04, 2020 11:56 pm ]
I believe the fibre washers are part number BTA101 and the copper the same but with a C suffix, as per the MKO link.
Author:  cooperess [ Tue May 05, 2020 8:28 am ]
winabbey-Do you have the dimensions for the copper thrust washers.
