1275 engine gearbox change https://ausmini.com/forums/viewtopic.php?f=2&t=97556 |
Author: | Minifreak_brg67 [ Sun Jul 29, 2018 6:03 pm ] |
Post subject: | 1275 engine gearbox change |
Hi I have a question about 1275 gearboxs I have one still attached to the engine that is a remote set up and is not selecting 2 gears ( carnt remember which two) what I want to do is put this engine on to a rod change 1100 gearbox will I have any issues |
Author: | simon k [ Sun Jul 29, 2018 7:29 pm ] |
Post subject: | Re: 1275 engine gearbox change |
no, rod change boxes have enough clearance for 1275 cranks (if the remote box isn't selecting 1st and 3rd, then it may just be the knuckles on top of the diff housing need their bolts tightened) |
Author: | Minifreak_brg67 [ Sun Jul 29, 2018 8:17 pm ] |
Bugger the other reason for doing this engine swap I don't want to change the mounts in the tunnel as I want to put the original 1100 motor back in once I have rebuild it, unless there's a way to fit the remote gear selector with no modifications |
Author: | deluxe67 [ Sun Jul 29, 2018 9:50 pm ] |
Your 1st post is not clear what you mean. What model car are you talking about? Simon says No, you won't have a problem putting a 1275 cc engine on a rod change gbox, but it's not clear you want to do this? I think the remote type is superior to the the rod change. Much more rigid. You need the bracket that bolts into the tunnel to support the remote housing rear rubber mount. Only one engine steady is needed versus 2 for the rod type box setup. |
Author: | Minifreak_brg67 [ Mon Jul 30, 2018 7:35 am ] |
I did read Simon's post incorrectly, the car is a 1974 Leyland s it hasn't been on the road for a while so I think it's time to use a 1275 engine that I was saving for a van that I was trying to get, as I am unable to get said van I want to put this 1275 engine in something and this car is sitting in my shed, when I get around to restoring this car I want it to be as it come out of the factory it will be a matching numbers car hence I don't want to go changing to much |
Author: | Scoop [ Mon Jul 30, 2018 7:51 am ] |
I would fix the existing remote gearbox that is already on the 1275. But if its for the Clubman then do the rod change. They will all fit, just depends what you want the car to have. |
Author: | simon k [ Mon Jul 30, 2018 9:29 am ] |
it's not a big change to fit the remote gearbox into a car that had a rod change originally - it's 3 holes for the remote mount and they're not really visible... but if it's in unknown condition and not selecting gears then it's probably not worth screwing around with Whichever gearbox you go with, do yourself a favour and at least put a new layshaft and layshaft bearings in it - takes about 5 minutes |
