https://ausmini.com/forums/
Quarter vent pivot
https://ausmini.com/forums/viewtopic.php?f=2&t=97532
Author:  Stibbsy [ Tue Jul 24, 2018 8:57 pm ]
Post subject:  Quarter vent pivot
What is under the nut at the pivot stem? I thought there was a washer and spring.
Mine is packed with about six 1/4" shim type washers.
Author:  Mick [ Tue Jul 24, 2018 11:02 pm ]
Post subject:  Re: Quarter vent pivot
Thats correct, although I seem to remember they're belleville (cup) washers to add some spring effect to the pivot. They're held in with a nyloc nut, and you can get a small socket ratchet in there to adjust the pivot resistance.
Author:  phillb [ Wed Jul 25, 2018 7:36 am ]
So if you can get a ratchet up inside the door can you adjust the resistance??
Author:  Mick [ Wed Jul 25, 2018 8:33 am ]
Certainly can. A 1/4 drive ratchet does the job perfectly.
Author:  Stibbsy [ Wed Jul 25, 2018 10:26 am ]
Thanks! Quarter vents are out. Just fitted new rubbers and have to get hinge repair kits and lock springs & pins. Can't seem to find any info on the pivot stems.
Author:  deluxe67 [ Wed Jul 25, 2018 2:33 pm ]
was it an absolute nightmare fitting the new rubbers? I was so traumatised I've only done one side!
Author:  phillb [ Wed Jul 25, 2018 5:04 pm ]
Thanks. I’ll have to give it a try.
