Pot joint adapters https://ausmini.com/forums/viewtopic.php?f=2&t=97519 |
Author: | Scoop [ Sun Jul 22, 2018 9:04 am ] |
Post subject: | Pot joint adapters |
Hi guys, I just saw these adapters on MED's site. You can use your pot joint outputs and run the hardy spicer drive shafts. ![]() Has anyone used them? http://www.med-engineering.co.uk/produc ... r-adaptors Cheers ![]() |
Author: | drmini in aust [ Sun Jul 22, 2018 9:47 am ] |
Post subject: | Re: Pot joint adapters |
And for those that don't know, Hardy Spicer joints fit fine on 850/998/1098 Mini rubber joint driveshafts. I run a pair since damaging an S one where the wire circlip sits. |
Author: | FNQ [ Sun Jul 22, 2018 12:04 pm ] |
I have slotted them in, and although only short term they were fine. ( my road motor with pot joints did a short stint in the sprints car ( hardy spicer). Literally plonk them on and away we went, and must of come off easily as well as i cant recall it, but the motor is sitting on a bench without the adpaters now. As i was doing an engine swap i cant tell you whether there would be any hassles doing in situ, but i would guess pop the top ball joints and plenty of swinging room |
Author: | simon k [ Sun Jul 22, 2018 9:17 pm ] |
I ditched the hardy spicers in favour of pot joints... |
Author: | drmini in aust [ Sun Jul 22, 2018 9:47 pm ] |
Back in the 60s? There were similar ones here that fitted the old rubber joint diffs. I bought a 3 synchro box once that had a pair on. Don't know who made them, maybe were local? |
Author: | Ian_B [ Mon Jul 23, 2018 6:06 pm ] |
Yes Kev I got a second hand set out of a mini K at the local wreckers Pretty sure Quinton Hazel. Was late 70s I was breaking the rubber ones at an alarming rate but these were awesome. |
Author: | drmini in aust [ Mon Jul 23, 2018 6:44 pm ] |
@ Ian_B Not Quinton Hazel ones that fit into the rubber couplings, I have used those. These ones looked like the flanges in the MED link above except they had a nut inside to hold them on the 850/998 diff output shaft. Used with Cooper S Hardy Spicer uni joint assembly. |
Author: | 9YaTaH [ Mon Jul 23, 2018 7:30 pm ] |
drmini in aust wrote: Back in the 60s? ,,,,,, maybe were local? When Australia actually made stuff ![]() ![]() |
