It is currently Mon Jul 14, 2025 1:44 am
PostPosted: Sat Jul 21, 2018 5:10 pm
Do you have to cut the parcel shelf trim to fit as supplied by MK online ? Cant see why it could not be made to size .Maybe because of the different dash ,although the panels are all the same. The rear shelf fits well.
Allen
PostPosted: Sat Jul 21, 2018 11:12 pm
From memory, mine was supplied oversize (not a MK item) and took some fettling to achieve the desired fit. I concentrated on getting it to fit properly inside the middle slot (the section above the switch panel, and at the curved ends, then just folded the excess up against the firewall and into the front rail. I think a bit of cutting was required. BTW, this was all done prior to fitting the firewall side panels.
PostPosted: Sun Jul 22, 2018 12:42 pm
Tuck / curl up under front rail up to / adjacent to behind the anodised / chrome strip
