It is currently Mon Jul 14, 2025 8:02 am
PostPosted: Thu Jul 12, 2018 7:48 pm
Hello All ,
My 1970 C.S has a MK 1 C.S engine could BMC have stock of the MK 1 engines and had to use them ?
Also my C.S has never had the metal strip, which is welded to the bottom of the roof channel one each side.I have seen one other mini without this strip.
Allen
PostPosted: Thu Jul 12, 2018 8:05 pm
if you check the MK1 register, the answer is "no", it was the other way around - late MK1s had MK2 engines
your engine number (9FSAY44226) is in the range of cars that were built in July '67
the last MK1 engine numbers were in the 51,000 range before they changed over to the MK2 blocks, and it looks like the numbering kept on going from there
viewtopic.php?f=44&t=90843
edit: is there any evidence spot welds for the drip rail at all? I took mine off early last year because a bit of rust was forming, I do want to put them back on but only when I find some that are correct for an Australian car
PostPosted: Fri Jul 13, 2018 7:52 am
and people swap and change "Cooper S" engines as they see fit...I once spoke to a man who had a MKII engine in a MK1 he was selling "because he wanted to keep the MK1 engine for his MK1 car"...
PostPosted: Fri Jul 13, 2018 8:23 am
Back in the 60s and 70s they were just another (but higher priced) Mini, when the engine expired most people got an exchange recond one from Repco or wherever.
Matching numbers? Nobody then gave a toss. ;)
PostPosted: Fri Jul 13, 2018 10:14 pm
I checked the mk 2 register early mk 2 had the mk 1 engine 9FSAY
Allen
PostPosted: Fri Jul 13, 2018 10:50 pm
Allen
only 2 of them?
PostPosted: Sun Jul 15, 2018 8:46 pm
I had what I believe to have been an early mark 2 as my first Cooper S in 1970. It was Malmo green, black interior, with factory flares, reverse lights wiring in the loom, Alternator with external regulator, Mark 1 heater, Mk1 brake booster and Mk1 9FSAy engine with 3 speed synchro gearbox.
A pity I never kept any paper work to verify numbers. :(
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Jul 16, 2018 7:22 pm
Could be a cheap Mk1 engine for sale soon :?
1965 Morris 850
1966 Morris Mini Minor
1967 Morris Cooper 'S'
1977 Leyland LS
PostPosted: Tue Jul 17, 2018 6:01 am
No such thing :!: :lol: .
PostPosted: Wed Jul 18, 2018 9:37 pm
maybe for sale I only spent $7000. on the engine and box
PostPosted: Fri Jul 20, 2018 2:21 pm
Hi
I own a early mk2 with a mk1 engine in it from factory.
PostPosted: Fri Jul 20, 2018 3:13 pm
minijoe69 wrote:
Hi
is it in the register?
PostPosted: Fri Jul 20, 2018 3:48 pm
Yes
PostPosted: Fri Jul 20, 2018 7:54 pm
minijoe69 wrote:
Yes
Sounds like car 501
PostPosted: Fri Jul 20, 2018 8:02 pm
That's right
Users browsing this forum: wild_willy and 88 guests
