Trim around the sppedo binnacle C.S mk 2 https://ausmini.com/forums/viewtopic.php?f=2&t=97497 |
Author: | p7676 [ Sun Jul 15, 2018 1:55 pm ] |
Post subject: | Trim around the sppedo binnacle C.S mk 2 |
What a fun job fitting these 2 trims ,seems to me they are not made correctly. I had to cut the trim where it fits under the binnacle and remove some board ,and I also had to cut where it fits next to the door seal. Anyhow they fit good now 3 hour job. Anyone had the same problem ?Tomorrow I am fitting the head lining I have fitted them in the past. Allen |
Author: | winabbey [ Sun Jul 15, 2018 2:20 pm ] |
Post subject: | Re: Trim around the sppedo binnacle C.S mk 2 |
p7676 wrote: What a fun job fitting these 2 trims ,seems to me they are not made correctly. Did you get the correct ones? The Mark 1 and 2 trims are different. |
Author: | p7676 [ Sun Jul 15, 2018 5:18 pm ] |
MK said they were the ones |
Author: | p7676 [ Sun Jul 15, 2018 6:02 pm ] |
the trim fits ok around the binnacle curve ,the ends are not correct that is why I had to modify them Allen |
Author: | Bill B [ Sun Jul 15, 2018 8:32 pm ] |
I can't explain or help with the problems you are having, but I completely sympathise. In the past I have made my own backboards and it is easy to make them slightly too big and stuggled to fit them into the curve of the dash. Recently bought a set of Mk2 boards for my mini K and covered them with my own vinyl and they fitted really easily at both ends!! Was very happy. |
Author: | bluehishouse [ Mon Jul 16, 2018 7:36 pm ] |
I struggled too, mine has clubby vents so double painful. Sent from my SM-G950F using Tapatalk |
Author: | deluxe67 [ Mon Jul 16, 2018 10:42 pm ] |
What is the best product (the board material) used to make these and door cards etc? |
Author: | Stibbsy [ Tue Jul 17, 2018 6:12 pm ] |
Doing the same job on mine at the moment. Initially bought 3.2mm Masonite from Bunnings, but not enough flex to fit. Today I am buying 2.5mm modelling ply. Will see how that works. |
Author: | Stibbsy [ Wed Jul 18, 2018 10:55 am ] |
Stibbsy wrote: Doing the same job on mine at the moment. Initially bought 3.2mm Masonite from Bunnings, but not enough flex to fit. Today I am buying 2.5mm modelling ply. Will see how that works. It works perfectly. |
Author: | winabbey [ Wed Jul 18, 2018 11:00 am ] |
A local auto trimmer may sell you the cardboardy stuff they use. |
Author: | Bill B [ Wed Jul 18, 2018 12:45 pm ] |
winabbey wrote: A local auto trimmer may sell you the cardboardy stuff they use. From experience, I don't like your chances of that ever happening. |
Author: | BBY755 [ Wed Jul 18, 2018 6:29 pm ] |
My mate's an upholsterer so he let me ring up and order some.....works well. Have enough for some cards if anyone close wants some...... |
Author: | Phil 850 [ Wed Jul 18, 2018 7:38 pm ] |
Bill B wrote: winabbey wrote: A local auto trimmer may sell you the cardboardy stuff they use. From experience, I don't like your chances of that ever happening. Got mine from the local trimmer. |
