Clubman GT Brake Master Cylinder Install https://ausmini.com/forums/viewtopic.php?f=2&t=97474 |
Page 1 of 2 |
Author: | GuamMini [ Tue Jul 10, 2018 1:52 pm ] |
Post subject: | Clubman GT Brake Master Cylinder Install |
![]() Is that plate really there? |
Author: | GuamMini [ Tue Jul 10, 2018 2:30 pm ] |
Post subject: | Re: Clubman GT Brake Master Cylinder |
http://www.classicmotoring.net.au/cmos/ ... inder.html |
Author: | Bill B [ Tue Jul 10, 2018 3:20 pm ] |
Quote: "Australian Minis from around 1969 to 1976 were fitted with plastic tank master cylinders, made by either Lockheed or Girlock. Lockheed master cylinders have a cast iron body and the Girlock master cylinders have an alloy body, but are otherwise the same. In contrast to the tin tank master cylinders, plastic tank master cylinders are 0.75" bore diameter for the brake, and 0.7" for the clutch. This style of master cylinder is no longer available new." Not sure this claim is accurate: I have here an alloy body with cast-in "LOCKHEED" and .7". The Abridged workshop manual quotes Clubman GT as having 0.7" as brake cylinder diameter. |
Author: | drmini in aust [ Wed Jul 11, 2018 9:55 am ] |
Only Oz Mini with 0.75 brake MC was the 850 I think. All Cooper S and GT here definitely had a 0.7" brake MC. |
Author: | gtogreen1969 [ Wed Jul 11, 2018 10:10 am ] |
Basic hydraulic theory says you should use .75 for the clutch because the larger piston moves more fluid. And use .70 for the brakes because the smaller surface area gives more line pressure. But it may differ depending on the engineering of the circuit. |
Author: | miniron [ Sat Jul 14, 2018 10:55 am ] |
Don't confuse the OZ Clubman GT with the UK 1275 GT. They are 2 different beasts. The OZ Clubman GT is a clubman fronted MK2 S. The running gear etc is all MK2 S in the clubman shell, apart from the last few cars which didn't have S blocks. Unique to OZ. The classic motoring link has the brake and clutch m/c sizes reversed. IIRC all OZ minis, apart from early 850s up to car No28044 which had a 0.75" dia m/c then 0.7" as the good doctor said, have 0.7" brake master cylinders and 0.75" for the clutch. Sometimes it's hard enough to get the clutch to release properly with the 0.75" m/c let alone with the 0.7". Edit: Early 997 Coopers with the brake pressure intensifier may have had a different m/c size to the 0.7". The dark blue shop manual TP 832 1971 seems to show this m/c as 0.7" up to car No 2056 then 5/8" dia after that. |
Author: | GuamMini [ Tue Jul 17, 2018 8:37 am ] |
miniron wrote: Don't confuse the OZ Clubman GT with the UK 1275 GT. They are 2 different beasts. The OZ Clubman GT is a clubman fronted MK2 S. The running gear etc is all MK2 S in the clubman shell, apart from the last few cars which didn't have S blocks. Unique to OZ. The classic motoring link has the brake and clutch m/c sizes reversed. IIRC all OZ minis, apart from early 850s up to car No28044 which had a 0.75" dia m/c then 0.7" as the good doctor said, have 0.7" brake master cylinders and 0.75" for the clutch. Sometimes it's hard enough to get the clutch to release properly with the 0.75" m/c let alone with the 0.7". Edit: Early 997 Coopers with the brake pressure intensifier may have had a different m/c size to the 0.7". The dark blue shop manual TP 832 1971 seems to show this m/c as 0.7" up to car No 2056 then 5/8" dia after that. Thank you for this information. I have found a friend thru this forum that is helping me get the right M/C for this GT. Thanks |
Author: | GuamMini [ Wed Jul 18, 2018 3:42 pm ] |
![]() Thank you Bill |
Author: | GuamMini [ Sat Aug 11, 2018 11:02 am ] |
How do I get to remove that last nut in the back in between the clutch master and the brake master? You have the clutch line and hydrolastic line blocking it not to mention the nut in the front holding the clutch master cylinder. It was a b/:;( getting that pin on the pedla out. Thanks |
Author: | GuamMini [ Sat Aug 11, 2018 11:04 am ] |
Author: | peterb [ Sun Aug 26, 2018 7:30 pm ] |
Post subject: | Re: Clubman GT Brake Master Cylinder Install |
It's there to align pedals evenly. |
Author: | GuamMini [ Mon Aug 27, 2018 2:19 pm ] |
peterb wrote: It's there to align pedals evenly. Thanks |
Author: | GuamMini [ Wed Sep 05, 2018 8:36 am ] |
