Tie Rod Ends https://ausmini.com/forums/viewtopic.php?f=2&t=97462 |
Author: | zulu_warrior1976 [ Sat Jul 07, 2018 1:17 pm ] |
Post subject: | Tie Rod Ends |
Hey Dudes, Am working on the tie rod ends as I need to replace the rubber boots. Just wondering if they need to be packed with grease and if so which sort? Cheers, B Sent from my iPhone using Tapatalk |
Author: | drmini in aust [ Sat Jul 07, 2018 2:03 pm ] |
Post subject: | Re: Tie Rod Ends |
If in doubt use molygrease. Castrol LMM or similar. |
Author: | zulu_warrior1976 [ Sat Jul 07, 2018 8:47 pm ] |
“Who’s the doctor they told you to go see”... not Dr. Dre Dr Mini!!! ^ this guy. Awesome. Thanks Kev |
Author: | 9YaTaH [ Mon Jul 09, 2018 9:36 am ] |
and if you have the slightest doubt about their wear or condition...throw some new ones on ![]() |
Author: | zulu_warrior1976 [ Mon Jul 09, 2018 10:40 am ] |
I'm thinking that will be the option... One of the tension springs has broken due to corrosion and I can only seem to buy a replacement from China in lots of 10,000... That would mean I have 9,999 to store in the shed! more than all the tie rod end tensions springs needed in the world! And at cheap cheap to replace them... why wouldn't I? B |
Author: | zulu_warrior1976 [ Wed Jul 11, 2018 10:21 pm ] |
Replacement torsion springs found on a set of TE boots. Job done. Sent from my iPhone using Tapatalk |
