https://ausmini.com/forums/
1970 mini accelerator cable twin carbies
https://ausmini.com/forums/viewtopic.php?f=2&t=97453
Author:  p7676 [ Wed Jul 04, 2018 8:43 pm ]
Post subject:  1970 mini accelerator cable twin carbies
Hello All
Where the accelerator cable fits to the acc pedal is there a clip to hold the outer cable from moving ?
Allen
Author:  Ian_B [ Wed Jul 04, 2018 9:09 pm ]
Post subject:  Re: 1970 mini accelerator cable twin carbies
No mate it sits in that little ferrule on the bulkhead
Author:  Bill B [ Wed Jul 04, 2018 10:55 pm ]
The inner wire is fed from inside the cabin through the small hole in the firewall into the engine bay, plain end first. The wire has a bead at its inner end that sits in a slot at the top of the accelerator pedal arm - no clip.
Mini King's parts catalogue shows a clip (11H1172) to hold the inner cable to the pedal arm, but I've never such a clip. It is not required as the cable has enough tension to hold everything in place.
The outer sleeve of the cable is fed onto the inner wire and locates in the "little ferrule on the bulkhead".
Author:  p7676 [ Thu Jul 05, 2018 8:32 am ]
Thanks guys I do not have the ferrule and I thought there must be something there although, I could not find anything in the parts book. Saved again by your knowledge and help TY heaps.
Allen
Author:  simon k [ Thu Jul 05, 2018 8:41 am ]
the ferrule on the bulkhead isn't removable - it really should be there... it's about an inch down from the crossmember
at least I don't think it's removable, I've never seen a shell without it, and they've always been painted as if they were spot welded to the shell
Author:  Phil 850 [ Sat Jul 07, 2018 6:40 pm ]
I just fitted a new cable to my mini and the old cable had a square nut on the end (loose), I thought it was odd.
When I fitted the new cable it went straight through the Fire wall so I pulled it out and fitted a small flat washer to stop the cable going through.
Obviously no ferrule on my car.
Anyone got a photo of the ferrule in place ?
