It is currently Mon Jul 14, 2025 3:21 pm
 Post subject: mini dizzy again
PostPosted: Sun Jul 01, 2018 5:23 pm
The clamping plate on the dizzy does it go below or above the dizzy its the plate with the long bolt ?
Allen
 Post subject: Re: mini dizzy again
PostPosted: Sun Jul 01, 2018 6:53 pm
Above.
PostPosted: Tue Jul 03, 2018 6:50 am
And also make sure you have the plate with the correct face up. The side mounting lug or lugs have an offset to make the plate sit away from the boss around the distributor so it does not clamp on the lower edge of the distributor clamping radius.
"Let us remove your "SHORTS"
