It is currently Mon Jul 14, 2025 4:37 am
 Post subject: Lucas 29D
PostPosted: Sat Jun 30, 2018 7:09 pm
Hi, Looking to find out what a Lucas 29D with AYB0370 should fit (no vacuum)? It was fitted to my mk.2 S ,many years ago. It is dated 7/71, Reddog.
 Post subject: Re: Lucas 29D
PostPosted: Sat Jun 30, 2018 7:56 pm
origmini was chasing info on a 29D4 AYB0370 stamped 62941129 8/71.
viewtopic.php?f=2&t=71932
The old Mini Kingdom catalogue has (B62941129-R) as an Australian MK II Cooper S. I am not so sure as the last MK2 Ss were built 3/71. If the dissy you have is 7/71 it would have been fitted to another type of vehicle.
PostPosted: Sat Jun 30, 2018 9:54 pm
Could be GT then? Same motor...
PostPosted: Sat Jun 30, 2018 10:06 pm
The standard MK2 S and GT are listed as AYG0175 in all my books.
PostPosted: Sun Jul 01, 2018 10:52 am
The dog drive and rotor also don't line up. It was running in my car many years ago. I wonder if the dog drive was altered from another vehicle? Where could I find a list of 29D Lucas Dist. with part no. and vehicle fitment ? Reddog.
PostPosted: Tue Jul 03, 2018 6:55 am
I have a 29 D here which also has no Vacuum and it is stamped AYH 0728.. 62941137A and it is dated 2.73 I was told it is from a Morris Marina GT or the like. I have never tried it is a Mini to see how it advances.
"Let us remove your "SHORTS"
PostPosted: Tue Jul 24, 2018 1:45 pm
After some more research I've discovered Lucas Australia distributor 62941129 was originally configured for a six cylinder vehicle and was specifically a later fitting for the Austin Kimberley E6 twin carby model (manual and auto).
If anyone has one of these that is configured for a four cylinder vehicle then the cam and cap (and maybe other internal parts) have been swapped. Nothing wrong with that as most Lucas distributors share common parts. In this case a non-vacuum advance body like this can be used for various 4 or 6 cylinder applications, although the part number stampings on the outside will then be incorrect.
PostPosted: Tue Jul 24, 2018 2:10 pm
Thanks very much for that, I was just going around in circles. The drive dog and rotar button also don't line up, but it would still run my motor, thanks, Reddog.
