It is currently Mon Jul 14, 2025 7:00 pm
PostPosted: Thu Jun 07, 2018 7:10 pm
Hi all
Just wondering if anyone out there has a picture or can advise the correct speedo for a early 70's Mini K? I have seen one with a mph and kilometres speedo and was wondering what was original.
Also after a BMC 2 spoke steering wheel. If someone has one out there to sell pm me
Thanks
PostPosted: Thu Jun 07, 2018 7:18 pm
no KM - 90MPH black face with a plain centre
PostPosted: Thu Jun 07, 2018 8:36 pm
ditto simon k.
Still have my original 1969 mini K with 90 mph black faced speedo. No sign of kph!
PostPosted: Thu Jun 07, 2018 9:09 pm
Thanks I did think that was the case
Tell me Bill B given your mini k is original I would love a photo of the binacle in order to check the temp and oil gauges.
Photo of of the inside would be handy
Thanks
PostPosted: Thu Jun 07, 2018 9:29 pm
Mini K has a grey faced 90mph speedo with a white needle.
Have a Nice Day.
PostPosted: Thu Jun 07, 2018 10:06 pm
This pic is from the Mini K Brochure.
PostPosted: Thu Jun 07, 2018 10:28 pm
It seems the temp and oil gauges have no “made in UK” hence mini K
Thanks gto
PostPosted: Fri Jun 08, 2018 11:19 am
Smiths had a factory in Australia. The dark grey faced speedos that also don't say "Made in UK" and the matching fuel gauges were made in Australia.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Jun 08, 2018 12:41 pm
Thanks all
Now for the hunt for a steering wheel
PostPosted: Fri Jun 08, 2018 1:24 pm
As others have said, the instruments for the Mini series were made by Smiths in Australia from mid-1968. They can be identified by the Comet Grey face colour and BMC Australia part number stamped on the rear (AYA9165 for the non-Cooper S models).
See below for the speedometer engineering drawing. The oil pressure and water temperature drawings are of a similar format and level of detail.
PostPosted: Fri Jun 08, 2018 1:52 pm
They had a factory in Ferndell Street Granville South. I lived near there and in the '70s had my speedo recalibrated by one of their technicians, who made it accurate at 45mph but a bit out everywhere else against a master clock. He also asked if I wanted the odometer left as was or returned to zero. He was happy for me to watch him test the oil pressure gauge using weights on a hydraulic plate. The gauge was very accurate.
PostPosted: Fri Jun 08, 2018 5:25 pm
Just to throw a spanner in the works, my '70 Mini K had a 140 km/h speedo. It's now in my Deluxe. It says "Made in the UK" on the dial. I'm confused because Google says metric speedo's weren't introduced until 1974 so how come my "K" had a metric one? (It reads the correct speed and my g/box has a "K" final drive). Odd...
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Fri Jun 08, 2018 6:35 pm
Assuming your not the original owner I would say that a PO has put a moke speedo in it.
I read somewhere that after the minis stopped using the centre speedo they went back to UK made kph speedos for the mokes.
PostPosted: Fri Jun 08, 2018 7:37 pm
That would explain it, had forgotten about Mokes.
67 Deluxe
Dry suspension
PostPosted: Mon Jun 25, 2018 11:02 pm
Anyone got a BMC horn pad and steering wheel for sale?
90 mph speedo as well
Thanks
