It is currently Mon Jul 14, 2025 9:21 am
 Post subject: Sump Crack Testing
PostPosted: Tue Jun 26, 2018 4:42 pm
How does one check for cracks in the sump before rebuild? The sump is bare but has what looks like an external crack.
 Post subject: Re: Sump Crack Testing
PostPosted: Tue Jun 26, 2018 5:08 pm
dye penetrant test?
PostPosted: Wed Jun 27, 2018 10:51 am
Where do you get the dye penetrant from?
PostPosted: Wed Jun 27, 2018 11:56 am
Pressure wash it inside and out
Pressure wash it again
Clean the crack area inside & out with prepsol
Add a couple of drops of blue food colouring to the suspected crack, wipe off with a clean dry cloth
The crack will be evident if it exists
PostPosted: Wed Jun 27, 2018 12:35 pm
get it welded up anyway - if it's not a crack now, it might become one later
PostPosted: Wed Jun 27, 2018 8:59 pm
I have a proper Rocol dye check kit, can check for nix if you want to send it down.
Can get it TIG welded by GR if cracked.
Got a pic?
PostPosted: Sat Jun 30, 2018 9:27 am
It is simple just splash talcum powder on the crack outside and put some Kerosene on the inside. The talcum powder will soon tell you there is seepage of any sort. It gets wet. "words came to me from the late Mini Guru JACK READ back in the 80s".
"Let us remove your "SHORTS"
PostPosted: Sat Jun 30, 2018 1:08 pm
If you find it is cracked you can get it repaired at Lynx Engineering according to the following advert from the 1970's. :shock: :wink:
PostPosted: Sat Jun 30, 2018 3:31 pm
$5 is OK, but $20!! I can get a whole new gearbox for that!!
PostPosted: Sun Jul 01, 2018 9:31 am
Lynx has moved!
http://www.lynxcorp.com.au/main.php?idx=home
https://www.lynxauto.com.au/
PostPosted: Sun Jul 01, 2018 10:27 am
Use another Mini K etc case. Restamp the box to the S number if you care enough to bother. :)
PostPosted: Mon Jul 02, 2018 10:07 am
I had one welded once. I drained the oil and took in the whole power unit. The welder flipped it upside down, welded the crack and even built up the broken off fins. Charged me next to nothing.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
