output shaft /drive flange question https://ausmini.com/forums/viewtopic.php?f=2&t=97397 |
Author: | guna mk1 [ Fri Jun 22, 2018 4:35 pm ] |
Post subject: | output shaft /drive flange question |
I am disposing of an old auto tansmission and have just removed the drive flanges to keep being the same as cooper s style I am guessing that the diff output shafts are different to minis and not worth removing but I would just like to clarify that thought Cheers |
Author: | timmy201 [ Fri Jun 22, 2018 4:49 pm ] |
Post subject: | Re: output shaft /drive flange question |
Yes, make sure you keep the whole set! Take out the whole diff assembly as one piece - crownwheel, diff, side covers and output shafts. There are also the collets and washers, bolts which are expensive to get new. The side covers are unique to auto cars but worth keeping |
Author: | guna mk1 [ Fri Jun 22, 2018 6:04 pm ] |
I really only want to keep the parts that interchange with minis |
Author: | timmy201 [ Fri Jun 22, 2018 7:42 pm ] |
Keep all these bits ![]() |
Author: | Bill B [ Sat Jun 23, 2018 12:04 pm ] |
The diff cage in autos don't seem to score up the seats where the planetary gear thrust washers spin - maybe better oil filtering? |
Author: | TheMiniMan [ Sat Jun 23, 2018 1:08 pm ] |
Bill, the diff carriers down score-up the thrutsts much (compared to manuals) simply because the automatics don`t spin one wheel (generally)... so there is very little (apart from simple cornering differentiating) time spinning the little gears, & very little "power" output in the autos generally being driven by little ol ladys ![]() |
Author: | guna mk1 [ Sat Jun 23, 2018 6:04 pm ] |
so is the diff carrier and the output shafts the same for manuals and autos cheers |
Author: | timmy201 [ Sat Jun 23, 2018 6:44 pm ] |
Looking at the middle one here, the manual and auto are the same (apart from the crown wheel) ![]() |
Author: | guna mk1 [ Sun Jun 24, 2018 10:21 pm ] |
thanks for your replies cheers |
