https://ausmini.com/forums/
Fitting k&n pancake. Needle change?
https://ausmini.com/forums/viewtopic.php?f=2&t=97396
Author:  astimini [ Fri Jun 22, 2018 3:11 pm ]
Post subject:  Fitting k&n pancake. Needle change?
I have a standard 998 and was thinking of just fitting a K&N pancake filter eventually fitting a stage 1 in the future.
At the moment I have the standard aac needle fitted. Will I have to change the needle if fitting the K&N or can I just richen the carb.
Author:  simon k [ Fri Jun 22, 2018 8:36 pm ]
Post subject:  Re: Fitting k&n pancake. Needle change?
you probably won't need to make any change at all... you won't know until you put the filter in and put an AFR tester on it
