Rear Wiring Harness https://ausmini.com/forums/viewtopic.php?f=2&t=97390 |
Author: | Stibbsy [ Wed Jun 20, 2018 12:55 pm ] |
Post subject: | Rear Wiring Harness |
Where does the rear harness make entry into boot space? Through the gaps at parcel tray that are sealed by sponge or the hole down low on left side behind rear seat back? |
Author: | winabbey [ Wed Jun 20, 2018 2:03 pm ] |
Post subject: | Re: Rear Wiring Harness |
Stibbsy wrote: Where does the rear harness make entry into boot space? Through the gaps at parcel tray that are sealed by sponge or the hole down low on left side behind rear seat back? The former. Attachment: Rear Loom Enters Boot above.jpg Attachment: Rear Loom Enters Boot.jpg
Author: | Stibbsy [ Wed Jun 20, 2018 4:35 pm ] |
Thank you! That's how I had it, until I saw that hole. |
Author: | Bill B [ Wed Jun 20, 2018 4:42 pm ] |
Stibbsy wrote: Where does the rear harness make entry into boot space? Through the gaps at parcel tray that are sealed by sponge or the hole down low on left side behind rear seat back? The "hole down low on left side..." , if it is in the rear firewall and not the floor, is for a locating prong from the rear seat backrest to poke through. There's another hole on RH side for the same. |
Author: | Convertible Mini [ Fri Jun 22, 2018 9:01 pm ] |
While the harness is out it might be the time to run an extra white wire to the back to supply future Electric Fuel pump. |
Author: | winabbey [ Fri Jun 22, 2018 9:07 pm ] |
Convertible Mini wrote: While the harness is out it might be the time to run an extra white wire to the back to supply future Electric Fuel pump. ... and perhaps a wire for reversing lights if you don't have the feature already. |
Author: | Phil 850 [ Sun Jun 24, 2018 8:47 pm ] |
winabbey wrote: Convertible Mini wrote: While the harness is out it might be the time to run an extra white wire to the back to supply future Electric Fuel pump. ... and perhaps a wire for reversing lights if you don't have the feature already. ... and reversing camera, ... and reversing sensors ![]() |
Author: | Stibbsy [ Mon Jun 25, 2018 10:00 am ] |
Quote: ... and reversing camera, ... and reversing sensors ![]() If I want all that crap, I may as well buy a Bini. |
