It is currently Mon Jul 14, 2025 3:32 pm
 Post subject: Rear Wiring Harness
PostPosted: Wed Jun 20, 2018 12:55 pm
Where does the rear harness make entry into boot space? Through the gaps at parcel tray that are sealed by sponge or the hole down low on left side behind rear seat back?
 Post subject: Re: Rear Wiring Harness
PostPosted: Wed Jun 20, 2018 2:03 pm
The former.
PostPosted: Wed Jun 20, 2018 4:35 pm
Thank you! That's how I had it, until I saw that hole.
PostPosted: Wed Jun 20, 2018 4:42 pm
The "hole down low on left side..." , if it is in the rear firewall and not the floor, is for a locating prong from the rear seat backrest to poke through. There's another hole on RH side for the same.
PostPosted: Fri Jun 22, 2018 9:01 pm
While the harness is out it might be the time to run an extra white wire to the back to supply future Electric Fuel pump.
"Let us remove your "SHORTS"
PostPosted: Fri Jun 22, 2018 9:07 pm
... and perhaps a wire for reversing lights if you don't have the feature already.
PostPosted: Sun Jun 24, 2018 8:47 pm
... and reversing camera,
... and reversing sensors :wink:
PostPosted: Mon Jun 25, 2018 10:00 am
If I want all that crap, I may as well buy a Bini.
