twin carbies 1970 cs https://ausmini.com/forums/viewtopic.php?f=2&t=97388 |
Author: | p7676 [ Tue Jun 19, 2018 10:01 pm ] |
Post subject: | twin carbies 1970 cs |
Fitting the carbies to the manifold. is it best to fit them to the heat shield then to the manifold as a pair ? Allen |
Author: | low n blown [ Wed Jun 20, 2018 7:46 am ] |
Post subject: | Re: twin carbies 1970 cs |
Manifold on, heat shield on then fit carbs last. |
Author: | phillb [ Wed Jun 20, 2018 5:11 pm ] |
As above. I always place the linkages between and pick up both at once and then holding it all together with the linkages staying in place place it on the manifold. Sent from my iPhone using Tapatalk |
Author: | simon k [ Wed Jun 20, 2018 5:31 pm ] |
phillb wrote: As above. I always place the linkages between and pick up both at once and then holding it all together with the linkages staying in place place it on the manifold. and then you bump one of the carbs against a stud and it moves out of alignment and then drop them both... I used to do something similar, now I just have one carb, much easier to deal with! |
