It is currently Mon Jul 14, 2025 9:07 pm
 Post subject: Oil gallery plug
PostPosted: Sat Jun 16, 2018 6:12 pm
There is one on the back of my block My small bore doesnt have it and not all 1275s have it
My mate thinks 1/8 pipe thread I dont know and need one.
Ideas gents??
 Post subject: Re: Oil gallery plug
PostPosted: Sun Jun 17, 2018 7:08 am
They were a solid brass plug originally, 0.503" diameter pressed into a 0.500" hole.
If it has been tapped out it's probably now 3/8 bsp or maybe 5/8 unf. Need to measure the plug.
If not tapped buy a new plug from minikingdomonline or Karcraft or other Mini place.
PostPosted: Tue Jun 19, 2018 12:08 pm
PostPosted: Tue Jun 19, 2018 12:35 pm
ohhh, that one!
I have at least one block with one of those - I'll check it - it does have a big flat head, but 1/8 BSPT would make sense given a/ it's an oil gallery and b/ that's the oil pressure outlet thread on the front of the block
PostPosted: Tue Jun 19, 2018 2:44 pm
Not seen that one either of my 1100S blocks.
PostPosted: Tue Jun 19, 2018 2:57 pm
Ian - in your picture, are you referring to the empty hole or the one with a big flat head already in place? If the latter then the parts books show this as a water jacket access hole. Some vehicles had a tap installed there.
PostPosted: Tue Jun 19, 2018 6:56 pm
The empty one mate .
Rob says 1/8 bsp .I dont understand pipe threads lol
PostPosted: Tue Jun 19, 2018 10:42 pm
Correct @ 28 tpi
PostPosted: Wed Jun 20, 2018 12:16 pm
Thanks all :D
Users browsing this forum: Bing [Bot] and 111 guests
