Oil gallery plug https://ausmini.com/forums/viewtopic.php?f=2&t=97374 |
Author: | Ian_B [ Sat Jun 16, 2018 6:12 pm ] |
Post subject: | Oil gallery plug |
There is one on the back of my block My small bore doesnt have it and not all 1275s have it My mate thinks 1/8 pipe thread I dont know and need one. Ideas gents?? |
Author: | drmini in aust [ Sun Jun 17, 2018 7:08 am ] |
Post subject: | Re: Oil gallery plug |
They were a solid brass plug originally, 0.503" diameter pressed into a 0.500" hole. If it has been tapped out it's probably now 3/8 bsp or maybe 5/8 unf. Need to measure the plug. If not tapped buy a new plug from minikingdomonline or Karcraft or other Mini place. |
Author: | Ian_B [ Tue Jun 19, 2018 12:08 pm ] |
Attachment: 20180619_115734.jpg
Author: | simon k [ Tue Jun 19, 2018 12:35 pm ] |
ohhh, that one! I have at least one block with one of those - I'll check it - it does have a big flat head, but 1/8 BSPT would make sense given a/ it's an oil gallery and b/ that's the oil pressure outlet thread on the front of the block |
Author: | drmini in aust [ Tue Jun 19, 2018 2:44 pm ] |
Not seen that one either of my 1100S blocks. |
Author: | winabbey [ Tue Jun 19, 2018 2:57 pm ] |
Ian - in your picture, are you referring to the empty hole or the one with a big flat head already in place? If the latter then the parts books show this as a water jacket access hole. Some vehicles had a tap installed there. |
Author: | Ian_B [ Tue Jun 19, 2018 6:56 pm ] |
The empty one mate . Rob says 1/8 bsp .I dont understand pipe threads lol |
Author: | Hinesy1275 [ Tue Jun 19, 2018 10:42 pm ] |
Correct @ 28 tpi |
Author: | Ian_B [ Wed Jun 20, 2018 12:16 pm ] |
Thanks all ![]() |
