It is currently Mon Jul 14, 2025 3:24 pm
PostPosted: Sat Jun 16, 2018 5:42 pm
Is this good value for money?
https://www.ebay.com.au/itm/MINI-REAR-R ... 2410738040
PostPosted: Sat Jun 16, 2018 7:49 pm
the repair kits themselves are between $25 (karcraft) and $40 (mini$port SA) each, so you're paying between $60 and $90 for the reamer and guide...
I've only ever used an adjustable reamer on them, as per Mick's how-to: viewtopic.php?f=25&t=45978
the photos are blurry, but it looks like an adjustable reamer...
PostPosted: Mon Jun 18, 2018 1:23 pm
Yes, it is an adjustable reamer.
The reamer alone is available for about $30 on Ebay, which using Simon k's numbers makes it $30-60 for the guide. While that sounds kind of expensive, I could not find a reamer guide long enough anywhere a year or so ago. So we used the live centre on the lathe to keep it aligned while reaming.
I'd probably buy that kit if I thought I'd do more than one pair of rear arms in my lifetime... which I probably will. :-)
Don't listen to what I am saying... just understand what I mean.
