https://ausmini.com/forums/
Spanner Sizes for SU carbs.
https://ausmini.com/forums/viewtopic.php?f=2&t=97371
Author:  Bill B [ Sat Jun 16, 2018 2:48 pm ]
Post subject:  Spanner Sizes for SU carbs.
Just fired the Mk1 after 25 yrs hibernation (the car, not me). Trying to get a basic running tune and got to wondering what spanner size is CORRECT for the fasteners on the choke and throttle interconnecting linkages?
I have always used a well-worn old 5/16 spanner but it doesn't fit every time.
New screw and nut fasteners are .3230inch across, putting them between 5/16inch (too small) and 21/64inch - a bit too big and not a standard spanner size that I have seen. 1/8inch Whitworth is a sloppy fit on a new fastener and too big for some used ones.
Author:  DavidE [ Sat Jun 16, 2018 3:39 pm ]
Post subject:  Re: Spanner Sizes for SU carbs.
2BA, Bill?
Author:  winabbey [ Sat Jun 16, 2018 5:20 pm ]
Does this help, or was it just the linkages you are talking about?
http://sucarb.co.uk/carburettor-jet-adj ... -16in.html
Author:  Bill B [ Sat Jun 16, 2018 5:48 pm ]
winabbey wrote:
Thanks Doug for the reply. I have a little jet spanner.
I only wanted to know about the linkage locking screws.
Author:  Bill B [ Sat Jun 16, 2018 5:59 pm ]
2BA, Bill?
Thanks David.
I thought BA referred to a type of thread diameter/pitch series, as used in Smiths and Lucas electricals etc. Did BA have their own spanner sizes too?
Author:  peterb [ Sat Jun 16, 2018 6:22 pm ]
You used to be able to by ignition spanners, all the weird tiny sizes.
Author:  winabbey [ Sat Jun 16, 2018 6:28 pm ]
The only other spanner type listed on the SU Carb site is this Whitworth set. Could Whit be the standard measure used on those linkage parts?
http://sucarb.co.uk/whitworth-spanner-set.html
Author:  DavidE [ Sat Jun 16, 2018 6:54 pm ]
2BA, Bill?
Thanks David.
Yes. Their AF dimension for 2BA is between the two dimensions you gave. There is a Britool 0BA / 2BA spanner on eBay UK at present, but the shipping cost must be via the moon.
Author:  DavidE [ Sat Jun 16, 2018 6:57 pm ]
2BA, Bill?
Thanks David.
Lots of good stuff here, Bill.
http://www.baconsdozen.co.uk/tools/conv ... charts.htm
Author:  winabbey [ Sat Jun 16, 2018 7:09 pm ]
https://www.ebay.com.au/itm/SIDCHROME-M ... SwSUJa4cJW
Author:  Mick [ Sat Jun 16, 2018 9:33 pm ]
I've never had any dramas, just using a metric equivalent on a 1/4" drive socket with extension.
I love the Sidchrome 1/4" drive socket sets around the engine bay on a mini. Especially useful around the manifold nuts and carb linkages, the lower radiator hose clamp, engine mount nuts...etc etc.
Author:  DavidE [ Sat Jun 16, 2018 9:37 pm ]
The metric equivalent of 2BA is 8.23mm.
Author:  Bill B [ Mon Jun 18, 2018 12:59 pm ]
Thanks peterb.
Yes I have a Sidchrome ignition spanner set.
Just checked them. I thought the largest size was 5/16inch which is too small.
But there is 11/32inch and it fits new and old screw/nuts well.
I have always found a spanner that will do the job but curious what is the right size.
DavidE says the 2BA is 8.23mm - the new fasteners are 8.20mm so that sounds about right.
And Winabbey has found a 2BA spanner on eBay. And it's old Sidchrome! Must buy it.
Thanks all.
