It is currently Mon Jul 14, 2025 5:29 pm
 Post subject: Shim material
PostPosted: Thu Jun 14, 2018 8:29 pm
Repositioned aluminium med rockers for offset exhaust valves.
Do I use aluminium shims or stainless.
I need two more but I chose aluminium Rob suggests stainless and he is a fitter of sorts lol
Ive dremelled little grooves to move the oil feeds inspired by GRs crankshaft and main bearing stuff.
The end two moved outward I need a thin shim and split pin or redrill a hole in a hard shaft.
My mate has tungsten drills
 Post subject: Re: Shim material
PostPosted: Thu Jun 14, 2018 9:36 pm
This space for rent
Surely aluminium would compress too easily to be a good shim material...?
PostPosted: Thu Jun 14, 2018 10:36 pm
I would think that too. Bit to soft I reckon.
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Jun 15, 2018 3:24 pm
as far as compressibility goes, there's no real difference... if you could contain water in the area under the rocker pedestal and not have it leak out, it'd be just as compressible as steel - that said, my rocker shims are steel... or am I talking about the wrong shims again? my rocker arm spacers are aluminium, and the shims between the rocker arms and the pedestals are steel
if you really want a scare, I'm about to put a set of these in the back of my Polo - camber and toe adjustment shims - a PLASTIC SHIM with varying thickness that goes BETWEEN the stub axle and the rear suspension beam, it's 2 pieces and one rotates inside the other, line up the marks you want for the adjustment you want and bolt the stub axle back on. The 3 bolts and 1 hole you see in this picture are what mounts the stub axle, which has the wheel bearing, brake caliper mount, everything...
PostPosted: Fri Jun 15, 2018 5:56 pm
This space for rent
Hmm.. I seem to remember a discussion about 4 metric yonks ago, about aluminium rocker _posts_ deforming under compression. Maybe I'm getting my wires crossed too.
PostPosted: Fri Jun 15, 2018 7:40 pm
yeah, the aluminium posts deformed, but they're a bit different to a shim that's under compression all the way across
PostPosted: Fri Jun 15, 2018 8:55 pm
Yes guys MED have an answer with LDX offset range It addresses a few issues hmm. :P
PostPosted: Fri Jun 15, 2018 9:20 pm
Wouldnt strictly have to be aluminium or stainless- normal steel should have a decent life within an oily rocker cover.
As for shims- if it was me I'd go to a bearing shop and buy a proper ground thickness shim- one thats preferably hardened.
PostPosted: Sat Jun 16, 2018 5:56 pm
Thanks all wont be going aluminium .:)
PostPosted: Sun Jun 17, 2018 7:48 am
Graham Russell and Minis Plus both sell rocker post shims laser cut from ground stock. 2 thicknesses. I used some when putting MED 1.5 rockers on a MK 1 S head.
PostPosted: Sun Jun 17, 2018 8:46 am
Hi Kev Its for the shaft as exhaust valves are offset
PostPosted: Sun Jun 17, 2018 6:39 pm
Rethinking my post from last night..
The MED rocker shaft is 17mm, not a common diameter but a 16mm flat washer would go close to fitting. I have used bored out flat steel washers to offset smallbore exhaust rockers to a 1275. Worked OK. The whole assembly is well oiled.
Users browsing this forum: Bing [Bot], goodie and 88 guests
