It is currently Mon Jul 14, 2025 9:08 pm
 Post subject: Boot hinge bolts
PostPosted: Mon Feb 08, 2016 7:24 pm
Could somebody please tell me if the 4 bottom Phillips head boot hinge bolts are painted body colour, along with the hinges.
 Post subject: Re: Boot hinge bolts
PostPosted: Mon Feb 08, 2016 8:05 pm
Mine are. :-)
PostPosted: Mon Feb 08, 2016 8:38 pm
Certainly are
PostPosted: Mon May 28, 2018 7:59 pm
Same-ish question - the nut / split washer / washer config for the boot hinge fixings.
Should there be a smooth flat washer per fixing to the body Philips head and boot studs as well as the split washer?
I'm just replacing some of these little items with new as it goes back together and want it correct.
Mat
1970 Mk2 Cooper S
PostPosted: Tue May 29, 2018 12:56 pm
Mat
The Mini King parts catalogue does not show the nut/washer arrangement for the hinges but I do fit flat washers, especially when it is pulling up against sheet metal panels to help spread the load.
PostPosted: Tue May 29, 2018 1:09 pm
See here - viewtopic.php?f=9&t=55558
Users browsing this forum: Bing [Bot] and 103 guests
