https://ausmini.com/forums/
slave cylinder c.s mk 2
https://ausmini.com/forums/viewtopic.php?f=2&t=97255
Author:  p7676 [ Sat May 26, 2018 2:53 pm ]
Post subject:  slave cylinder c.s mk 2
The spring on the slave cylinder is extremely hard to connect. Should I screw in the 1/4 bolt ? New clutch and slave cylinder have been fitted any ideas ? TY Allen
Author:  Bill B [ Sat May 26, 2018 6:19 pm ]
Post subject:  Re: slave cylinder c.s mk 2
Yes. It is a little bugger... I have copied a friend's idea to reduce the tension in the spring as it doesn't need to be so strong. A short length of steel wire/rod (even a nail) bent at both ends to go between the spring end and triangle plate on the clutch arm. Just needs to have slight tension all the time.
Author:  Matt I [ Sat May 26, 2018 10:18 pm ]
Drop it in your toolbox and forget it was ever there... They don't need it and the clutch mechanism works better without.
