It is currently Mon Jul 14, 2025 8:48 pm
 Post subject: slave cylinder c.s mk 2
PostPosted: Sat May 26, 2018 2:53 pm
The spring on the slave cylinder is extremely hard to connect. Should I screw in the 1/4 bolt ? New clutch and slave cylinder have been fitted any ideas ? TY Allen
PostPosted: Sat May 26, 2018 6:19 pm
Yes. It is a little bugger... I have copied a friend's idea to reduce the tension in the spring as it doesn't need to be so strong. A short length of steel wire/rod (even a nail) bent at both ends to go between the spring end and triangle plate on the clutch arm. Just needs to have slight tension all the time.
PostPosted: Sat May 26, 2018 10:18 pm
Drop it in your toolbox and forget it was ever there... They don't need it and the clutch mechanism works better without.
*witty signature*
Sapphire Blue Deluxe spread across three parts cars, two sheds and a driveway...
Users browsing this forum: s-c1293 and 108 guests
