https://ausmini.com/forums/
Timing Chains and Sprockets
https://ausmini.com/forums/viewtopic.php?f=2&t=97253
Author:  kiwiinwgtn [ Fri May 25, 2018 9:17 pm ]
Post subject:  Timing Chains and Sprockets
Hi what brands are people using for timing chains and sprockets these days. Prefer adjustable
Thanks
Kiwiinwgtn
Author:  mickmini [ Fri May 25, 2018 10:34 pm ]
Post subject:  Re: Timing Chains and Sprockets
i have a MED vernier one. Nice bit of gear. Can't remember the brand of chain but seem to recall it being German.
Author:  rodmac [ Fri May 25, 2018 10:51 pm ]
Iwis chains seem to be highly regarded
Author:  simon k [ Tue May 29, 2018 12:40 pm ]
I use the rollmaster adjustable set - cheap, adjusts to where the cam is meant to go, turns the cam
Author:  kiwiinwgtn [ Tue May 29, 2018 8:02 pm ]
where can you purchase a rollmaster set. ta Kiwiinwgtn
Sent from my SM-J530Y using Tapatalk
Author:  simon k [ Tue May 29, 2018 10:24 pm ]
just about anywhere... price for the same thing varies from :shock: to :wink:
http://minisport.com.au/mini-rollmaster ... d-sprocket
https://www.ebay.com.au/itm/BMC-Morris- ... .l4275.c10
seems like it comes with an IWIS chain...
Author:  drmini in aust [ Wed May 30, 2018 12:57 am ]
I found the rollmaster keyways confusing, I used an offset cam key instead.
Author:  Scoop [ Wed May 30, 2018 9:20 am ]
There is a nice How To on here for the rollmaster. I have used them a few times, good once you get your head around all the slots!!
Author:  Ian_B [ Fri Jun 01, 2018 8:49 pm ]
Rollmaster done my head in until I finally worked it out .They dont supply good enough instructions but they are a good set and are available for tunnel bored blocks.
