It is currently Thu Jul 17, 2025 9:11 pm
PostPosted: Sun May 20, 2018 8:29 am
I am a little confused with all the talk about 1275 Cooper S distributors. As I understand it all the above distributors are used and none have the vacuum advance. I am not trying to be a concourse winner, I just want my Cooper S to run properly.
So the quesion is which do I use?
PostPosted: Sun May 20, 2018 8:57 am
1970? Then 29D
These were used from 1969 right through into the GT range.
PostPosted: Sun May 20, 2018 9:30 am
The 25D was used in many different models - Mini, Lotus, MG, Triumph etc with vacuum advance
23D was the non- vacuum advance version
29D was Aussie made (others were UK) but can share some parts
PostPosted: Sun May 20, 2018 9:51 am
Yes, I should add as I didn't answer the original question of your post.
The 29D is just a little harder to rebuild, being a bit of a quirk. The 23 and 25D dizzys are more supportable as there was millions of them in existence.
PostPosted: Sun May 20, 2018 8:44 pm
I have brand new 23D after market Electronic ones for sale $125.00.
"Let us remove your "SHORTS"
